12-26-2023 01:11 PM
12-26-2023 04:21 PM
Same problem here, google closed the other thread about this problem hoping it would go away. Very annoying.
I either have to spend another £400 on alarms by google or just get the fire angel for £15 each.
Guess which way I am going
12-30-2023 04:23 PM
Hey everyone,
@DavidToma38, thanks for reaching out to the Community. I’d be happy to help you with Nest Protect. Let’s check it out. A few more questions: do you have a wired or battery-powered Nest Protect? What is the software version of the device? To check, go to the Nest app > Device Settings > Technical Info > Software.
Battery life varies greatly depending on usage: how many times Nest Protect detects smoke or carbon monoxide (CO) and sounds the alarm, how often Path light turns on, where the Nest Protect is placed in the home, etc.
Here are some things you can try to extend the battery life:
@DaveH2, it looks like the previous discussion you mentioned was automatically locked by the system due to inactivity for over 30 days; posts are not being blocked. Please give the steps above a try and let me know how it goes.
Lance
