07-30-2023 10:21 AM
I have a 3rd generation NEST thermostat and is now registering a low battery. I am able to recharge it but only holds for 2 days. Contacted Nest support and was basically told the battery is not replaceable - throw the unit out and buy a new one. If I would have known that Google Nest considers these to be disposable units I would have stuck with my Honeywell which never let me down.
07-31-2023 04:13 PM
The C wire keeps the battery charged. Make sure it has power.
08-04-2023 06:38 PM
Hello folks,
I'm chiming in to see how I can help.
Thanks for the input, @Dave991.
@Disappointed3, oh no! I'm sorry to hear you're having an issue with your Nest Thermostat not holding its charge. Let's sort this out.
I understand that in most cases, the Nest Learning Thermostat can charge its built-in battery using your heating and cooling wires. But there are situations where you have to connect a Nest Power Connector or a Common wire to consistently deliver power to the thermostat. Please check out this article and let us know if you have more questions.
08-07-2023 11:38 PM
Hi Disappointed3,
