7 Wire system to Nest thermostat
Gabe3
I plugged my info into the compatibility page and it says the nest will work in my home however I have 7 wires and only 6 spaces for wire in the nest. Do I need to get the C adapter for it or am I able to make it work without adding the C wire?
EdmondB
Hello Gabe3,
We appreciate you reaching out to the Community. To help us determine the right wiring setup for your Nest Thermostat, could you kindly share a photo of the existing thermostat wiring?
Below are the steps on how to upload a photo or video:
1. Hit reply or Start a new post.
2. Click Insert Image.
3. Choose an image source location.
4. Follow the on-screen instructions
Also, you can tap the "Drag and Drop" option. Maximum attachment is 5 MB.
Edmond
