A/C unit outside does not come on
Jasonr9546
My AC worked with the old thermostat. I switched to the nest thermostat and now my A/C does not work. I'm trying to rule out my thermostat before I go open the outside unit to see if it's something is wrong inside the unit. Attached are all the pictures. I also tried troubleshooting by switching the Y1 and green wire but same problem no A/C.
6 REPLIES 6
@Jasonr9546
Have you checked if you blew a fuse on the control board?
I am getting 24v to the outside unit from the thermostat. Something is wrong with the outside unit. When I hold in one of the contactors the unit comes on. I think it's the control panel or transformer inside the unit that has gone bad.
zoeuvre
Hi Jasonr9546,
Thanks, we appreciate you checking that for us. Currently, the best option is to contact a local HVAC technician to check your control panel. Once you have an update, let us know and we'll be happy to help.
I appreciate your assistance, @Patrick_Caezza.
zoeuvre
Before I mark things as resolved, I wanted to check and see if there might be anything else you needed on this or to see if you had any other questions. If there's more you need, just let us know.
Jasonr9546
I am on vacation but hopefully the wiring is correct and when I get back I'll fix it. You can go ahead and close this.
zoeuvre
Hey Jasonr9546,
As you’ve requested. I'm going to lock this thread and mark it as complete. Feel free to create a new one if you have more questions or have other concerns in the future.
