06-18-2022 09:30 AM
AC not cooling as scheduled in evening and when try to adjust gives message above temp "in 2+ hours". Eventually cools so AC is working. How can I turn off this off?
06-22-2022 02:40 PM
Hi GeraldF,
Thanks for reaching out. The "delayed" message that you're getting might be a symptom of a power issue. Could you tell us how your Nest Thermostat is wired? Also, please review the power readings of your Nest Thermostat by going to Settings > Technical Info > Power.
Edward
06-22-2022 03:45 PM
06-25-2022 11:32 AM
Hi GeraldF,
Thanks for the response. I'd love to know more about this. Please share a photo of how your Nest Thermostat is wired. Also, please let us know the Voc, Vin and Iin values under that power readings so we could investigate further.
Edward
06-27-2022 08:12 PM
I'm having this exact same issue! Was there a solution to this/best practice of what to do? Thank you!
06-28-2022 09:28 AM
Hi noellec88,
Thanks for letting us know. Like I mentioned above, in some cases this is a symptom of a power issue. Please let us know which type of Nest Thermostat you have and the power readings so we can investigate further.
Edward
06-28-2022 03:13 PM
As an update to this: the thermostat is set to 75 but apartment is at 85. Levels are:
-battery: 3.776
voc 35.46
vin 8.20
lin 20 mA
thanks so much for your help!
06-28-2022 03:40 PM
Hi noellec88,
Thanks for the response. Just to verify, is your system running when you got the power readings? Also, are you getting a "delayed" message on the display?
Edward
06-28-2022 04:12 PM
Yes system is running and there is no delayed message
06-29-2022 09:45 AM
Hi noellec88,
Thanks for the response. Just to clarify, is this only happening when you're expecting the cooling to turn on when scheduled? Is the cooling working fine if you adjust the cooling using the app or the dial?
Edward
06-29-2022 09:53 AM
This is happening no matter if I set the temperature on the app or dial. We don't use the schedule feature.
06-29-2022 09:57 AM
Hi noellec88,
Thanks for confirming. We'd like to know more about this. Please fill out this form so we could investigate further.
Edward
07-02-2022 11:06 AM
Hi noellec88,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Please keep your lines open as they may reach out to you anytime soon. Also, please be advised that this thread will be locked after 24 hrs.
Edward
