Battery won't hold the charge
Halbrand
I just installed a Nest thermostat gen 3. It won't turn on. Just hooked up with W1, Rh, Y1,and G wires. I checked the breaker and it's on and rewired to test and making sure that they're seated properly.
Any advice would help. Thanks.
Houptee
Put red eire on RC on nest.
That nest third generation thermostat you have does have the ability to use either of the Y wire or the W wire to reach the common side of the power transformer and charge the battery. However, this takes time and what you need to do is get there faster. What you need to do is take the nest display off the thermostat base, flip it over you’ll see a USB, charging port, plug it into a USB charger for several hours. Then reinstall the display onto the back plate. The best way to ensure you have a good current to charge the battery of a Nest third generation, is use a Power Common wire. There is a small percentage of systems that have digital control boards that will not allow this back door feeding for the power common to charge the battery.
Ken, The AC Cooling Wizard
We appreciate your help here, @CoolingWizard and @Houptee.
@Halbrand, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Thanks for assisting, Mel.
@Halbrand, I'm checking in to make sure that you've seen everyone's response. Please let us know if you have any additional questions or concerns.
It looks like we haven't heard back from @Halbrand, so I'm going to lock the thread in 24 hours. If you have any further questions or concerns, feel free to create a new post.
