Can I monitor temp without connecting to a thermostat?
Cmccarty13
I have a wine cellar in my basement and I'd love to be able to check the temp / get alerts in my Google home app rather than buy a 3rd party product with its own app.
Is it possible to set up a nest thermostat sensor purely to read the temperature but not have the nest thermostat try to adjust the temp? Ideal scenario, Id like to have an alert at a certain temperature too.
6 REPLIES 6
Frustratedddd
You could always buy a new/used thermostat, and just use that as a sensor. I have one in my conservatory where I can monitor the temperature, and an alert comes if a low reading shows.
Thanks Frustratedddd for the reply.
Jhonleanmel
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Mel
Mel
I suppose we can close it. The answer isn't ideal but it works.
Jhonleanmel
Hi Cmccarty13,
Thanks for understanding. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
