11-03-2022 03:36 PM
I've had a NEST for 3 years. Had to replace the Thermostat (if failed). Sensor won't connect. I removed and readded the sensor, changed the battery (even though my tester said the battery was still good), placed the **bleep** sensor ON TOP OF the thermostat (is THAT close enough?)... still won't connect. Getting cold toes here... and a heated brain.
Nest trouble shooter only tells me to do what I figured out and did myself. wow, great support.
11-03-2022 03:45 PM
Auntibear61,
i’m sorry that you’re having trouble have you tried by chance going into the thermostat and removing the temperature sensor, then perform a reset of the thermostat, then re-initiate the thermostat, and then try to add the temperature sensor? I hate to say do a reset but sometimes I think giving the thermostat a full enema have a reset works to resolve some problems
Ken, The AC Cooling Wizard
11-07-2022 11:21 AM
We appreciate your help here, @CoolingWizard.
@auntyBear61, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
11-07-2022 05:38 PM
Impatient me called Nest and got essentially the same guidance. Reset the thermostat and all was well! Didn't even need to remove the sensor. Thanks so much; I'm happy to confirm the accuracy of your solution
11-08-2022 09:23 AM
Hey auntyBear61,
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Mel
