Can I order and replace batteries for Nest Thermostat E? USB charging is not working
GeorgeMC
Can I order and replace batteries for Nest Thermostat E? USB charging is not working even after several hours of charging.
aperezdeleon
Hi GeorgeMC,
Thanks for reaching out to our community.
I understand it can be frustrating if your Nest thermostat doesn’t seem to be holding a charge. Let’s see what is going on.
Is your thermostat display showing a status light when charging or plugging it on the wall? When did your thermostat start showing this behavior? I'd like to know if this thermostat was recently installed as well.
Do you see any error codes in your display once you plug it on the wall? If the thermostat turns on, it’d be great if you could go into Settings>Technical Info>Power. Please let me know what power readouts you see, including the battery level.
Let me know how it goes.
Angel.
Thank you for replying. It works now after 6 hours of USB cable charging.
aperezdeleon
Hi GeorgeMC,
Thanks for the update.
I’m glad your thermostat is back up and running. Be sure to keep an eye out for the power readouts on your thermostat's settings alongside the battery level for the next few days. If the battery level drops again, keep me updated.
Let me know if you have any other questions or concerns.
Angel.
