04-06-2023 12:12 PM
I've recently installed some Samsung Mini Split AC/Heat units. I would like to control the one in the living room with my Nest Thermostat (it recently controlled my gas heating and AC system but have disconnected them for the new system.)
Has anyone done that or know how that could work?
Samsung sells a Samsung MIM-A60UN device which I think would work but not sure.
Thank you in advance!
04-12-2023 12:54 PM - edited 04-12-2023 12:55 PM
Hi mjolnir,
Thanks for posting in the Google Nest Community forum. I'm sorry for the delay. What type of Nest Thermostat do you have? Please visit this link to check what type of thermostat you have. Please share a photo of the wires connected to your control board.
04-15-2023 01:43 PM
Hello folks,
Thanks for the assistance, Jenelyn.
@mjolnir, I wanted to see if you still needed help. Please let us know if you have any other questions or concerns.
04-15-2023 02:06 PM
Sorry, missed your response.
I have the Nest Learning Thermostat, 3rd Generation, Polished Steel, Serial: 09AE01AF401907V6.
I would upload an image but it says I do not have permission to do so.
However I will describe how the wires are currently set up:
Y1 - White
G - Green
W1 - White
C - Green
RH - Red
Thank you!
04-17-2023 05:18 PM
Hi there, just following up on this question. Thank you!
04-19-2023 07:56 AM
Thanks for getting back to us, . Please send us a photo of your control board where the other end of the wires are connected together with the photo of how you wired it to the Nest Learning Thermostat base. You can send us a photo by clicking on this link by tapping your response, then tap the camera icon to insert photos.
Thanks for your assistance here, Jenelyn and Mark.
04-19-2023 08:04 AM
Hi Zoe - the link you sent me just refreshed the page. However I did note in the previous char how the Near is wired to the old HVAC system.
What I'm looking for is a way to control the Smart Things compatible Samsung AC units with the Nest thermostat. Just one of them, the one in the living room. I was hoping there was a way to connect them. I have seen adapters and wiring kits online but nothing from an established brand.
04-20-2023 10:56 AM
Thanks for the follow-up. Some 3rd party transformers or adapters can cause problems or damage your Nest thermostat, even if they claim to be Nest compatible. However, for the best resolution, you can consult this matter with a Nest Pro technician to further check the compatibility of your Samsung MIM-A60UN 24VAC Thermostat Adapter with the Nest Thermostat.
Let us know if you have any other questions.
04-20-2023 11:10 AM
Thanks, I will do that, much appreciated!
04-20-2023 11:36 AM
Hey mjolnir,
Sounds like a plan! In the meantime, I'll go ahead and lock this thread within 24 hours. If you run into any more questions in the future, please feel free to create a new thread.
