03-19-2022 08:36 AM
Ive got a NEST learning thermostat - inherited it with a house I bought. Reset it using the app but I can only find a setting for heating and can’t find a hot water setting (I don’t have a combo boiler) altho I know the previous owners of my house used it for their hot water. It doesn’t come up as an option under settings either in the device or the app. Can anyone suggest what’s happened?
03-19-2022 09:13 AM
Try this on the display - Settings - Equipment - Pro setup - System Boiler .
Make sure when you get to the on/off you choose connected, otherwise the hot water will not show.
03-21-2022 05:07 AM
Hi there @Paddington62, thanks for reaching out.
You can set it up as @Frustratedddd said, from Settings > Equipment > Continue > Pro setup - System Boiler with Hot water with On/Off. Let me know if you need more help.
03-19-2022 09:13 AM
03-21-2022 05:07 AM
03-22-2022 03:38 PM
Thanks for v helpful answer. I should have come here first!
03-23-2022 04:52 AM
You're most welcome. That's great news. I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
