Charging the thermostat battery
JMartin7476
How long and how often do you need to charge the battery on the thermostat? And will this fix an E73 error code?
@JMartin7476
 An E73 error on a Nest thermostat indicates that no power is reaching the Rc (cooling) terminal. Check the furnace/air handler
