Compatibility help
Amgentry
 Greetings everyone.  I'm needing your help to determine if i can install a nest thermostat?  I am ignorant unfortunately when it comes to wiring 😕  I've posted pic of current configuration and just had Goodman 2.5 HVAC system installed.  Just wanting to install basic nest thermostat if possible?  Thanks all!!! Greatly appreciate your input:)
EdwardT
Hi Amgentry,
Thanks for reaching out. Based on your current wiring, it looks like it's compatible with the Nest Thermostat and you can wire it as it is. In most cases, Google Nest thermostats can charge their built-in battery using the customer’s heating and cooling wires. But there are situations where they may need to connect the Nest Power Connector or a common or C wire to consistently deliver power to their thermostat.
Edward
MelbaDT
Checking back in should you still need help here. Let us know by replying to this thread.
Melba
MelbaDT
Melba
