Connection issues for nest thermostat
Mariazee
I have a nest learning thermostat that was synced with my iPhone and iPad.  I purchased a new iPhone and iPad and now cannot get the thermostat to connect to either one.  I want to be able to look at it while I’m away but cannot do that now.  Please help.
6 REPLIES 6
Frustratedddd
The easy way is to add your new items is in the ''Add family''. All is explained in the user manual.
Give it a try to see if that helps.
Thank you but I don’t know where my manual
They are easily available on the Google site to view or download.
MelbaDT
Thanks for answering and for your suggestion, Frustratedddd.
Mariazee, you may find your beginner's guide to your Nest thermostat here: https://bit.ly/39eNlUO
Also, our thermostats require only a one-time setup. If nothing was changed on it, you just need to download the Nest app on your new iPhone and iPad then make sure to log in using the same email address and password you're using on your old mobile devices.
Melba
MelbaDT
Hey Mariazee,
Checking back in if you still have some questions about your Nest thermostat?
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
