Contacting NEST: Unit dead after less than 9 months
lkendall605
Had the Nest Learning Thermostat (2nd gen) professionally installed 9 months ago.  It worked for a short time and then started to have problems.  Now it's not connecting to the heater or air conditioner.
@lkendall605
If your thermostat was installed 9 months ago, then it is not a 2nd Gen.
How to tell which Nest thermostat you have
Can you post a picture of the wired base?
If the camera icon isn't present yet, you can use the imgur.com upload site and post the link it provides here.
