Do I need power connectors for all thermostats
scbristol
I have 2 thermostats, do I individual power connectors for each thermostat?
Yes, you will need a separate Google Nest Power Connector for each thermostat that you have.
9 REPLIES 9
MrVacca
Silver Product Expert
Hi @scbristol - it all depends on how your house heating is set up and if it's considered a zoned system. This support article from Google does a great job showing the different set ups and how you can figure out which one you have.
Hope this helps!
Bill
Can you install 1 power connector at a time or is it best to take care of both at one time? Thanks
Jeff
Hi scbristol,
I just wanted to jump in real fast to see if you saw Patrick_Caezza's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
Jeff
Hey Etabeyta,
While you could install one at a time, to ensure that you get proper performance from your HVAC system, it would be best to install them both at the same time to make sure you don't have any power issues at either point. If you can only do one for now, however, you could still start there and get to the second one when possible. Let me know if you have any other questions.
Jeff
Etabeyta
Thanks for the advice. I plan to do both at the same time
Everything is taken care for f. Thanks
Jeff
Sounds good, Etabeyta. Before I mark this as resolved, is there anything else you might need or any other questions you might have?
Jeff
Jeff
Sounds great, Etabeyta. Big thanks to all who helped here in finding our resolution.
Jeff
