12-18-2022 06:53 PM
I have a nest gen 3 set up with a dual fuel system heat pump and LP gas furnace and have had for a few years now. I’m not really impressed with the performance of the system in its current state with the nest thermostat. Wires y1 g o rc w1 w2. It has temp lock outs that control which system to use and I find it very inefficient. As I have to set a temp when it will shutdown the heat pump and turn on the furnace. I can’t lower the temperature at night because the heat pump takes too long to warm the house up. I stumbled across a discussion regarding heat pump balance and was wondering what I wires I’d have to swap to get this option to show. After reading about about heat pump balance it seems that this may make the system work the way I want to as it will split between gas and electric. Any help is appreciated.
12-18-2022 08:14 PM - edited 12-18-2022 08:21 PM
No wires need to be switched you do it in the settings.
Read this article.
12-23-2022 06:44 PM
Hey Zoezoe,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
12-26-2022 08:51 PM
Archie
12-27-2022 09:31 PM
Hello there,
Archie
