12-20-2023 11:34 AM
I am trying to enter the entry code in my app.
the entry code starts with an M but the app on phone will only allow numbers first! What do I do?
12-25-2023 04:40 AM - edited 12-25-2023 04:41 AM
It sounds like you may be using the wrong app for setup or perhaps not reading the right key/code?
First check which model of thermostat you have:
How to tell which Nest thermostat you have - Google Nest Help
Nest Thermostat
For the Nest Thermostat model, use the Google Home app. The QR code and setup key are physically printed on the back of the thermostat. Follow these steps:
Get started with your Nest Thermostat - Google Nest Help
Nest Thermostat E and Nest Learning Thermostat
For Nest Thermostat E and Nest Learning Thermostat models, use the Nest app. The QR code and setup key are in the settings on the thermostat itself and are not printed on the device. Follow these steps:
Add your Nest thermostat to the Nest app - Google Nest Help
Happy holidays!
Nest Thermostat
Happy holidays!
