12-04-2021 07:53 AM
Purchased a home with the Nest. When I manually turn on the heat, it works great, but once it reaches the right temperature, the fan keeps running. The app won't let me turn it off, but only gives me an option to run it for a certain amount of time. Even if I pick the lowest option (15 minutes) after an hour it is still running. The only way to turn it off is to turn everything off, so I can only use the Nest manually. How can I fix this?
12-04-2021 09:43 AM
There are a few different reasons this could happen. It also could depend on which thermostat you have. (these suggestions are general and not necessarily specific to your thermostat or HVAC equipment)
Good Luck!
04-07-2022 08:34 PM
My unit is doing the same thing. Have you found a solution?
07-28-2022 07:48 PM
My unit just started doing the same thing. Did you find an answer to your question?
08-03-2022 10:59 AM - edited 08-03-2022 11:00 AM
Following. Similar issue here. Moved into a home with a Nest, which was working great for the past month, until last night the fan just kept running (on AC) and even after resetting, rewiring, and turning the system to OFF, the fan is still on.
08-25-2022 09:50 AM
Mine too !?!?!?!?
10-08-2022 08:14 PM
We are also having the issue that the fan runs constantly in AC after having to reconnect after changing wi-fi mode. I don't see any good solution in the replies. Does Google respond here?
10-16-2022 02:43 AM
Same issue here. Any solution yet?
10-16-2022 10:20 AM
Same here and in addition getting not enough power for wi-fi error. It worked fine for A/C and for one day for heat. Followed all the solutions including charging the battery via an outlet but nothing now. Ready to trash this thing!
10-18-2022 01:32 PM
Same issue as above. Worked fine for several months but now fan runs almost constant. This is frustrating. I guess no support from google.
12-28-2022 02:47 PM
Plus one to this topic. One thing that has changed on my nest, because it's been running flawlessly for 5 years prior, is that after I connected nest to my Google Home automated network and possibly enrolled in some climate control sustainability feature, this is when my fan began running 24/7. Please share when you have a solution and I will as well.
12-28-2022 03:00 PM
The end result for me was google admitted it was a faulty product. Then tried to have me return the brand “new” $120 product in exchange for a “used” $80 one. Refused to send a new one, refused to give a refund, refused to compensate the $40 difference between a new and used one. So now I have a thermostat that doesn’t work (this was already the second one by the way) and I’m out $120. Worst customer service ever.
12-28-2022 03:11 PM
SOLUTION: Disable/Cancel Nest Renew from within your Nest App...
My issue didn't start until recently when adding bells and whistles to an already working system installed several years ago. I ventured down this path when adding Nest to my Google Home automations....The problem is not any google home automation...its within the Nest app specifically...Again, DISABLE NEST RENEW
