Forgot pin help
amyalves
I forgot my pin and my device was removed from my app while trying to switch to Google home
David_K
Let's try these steps:
  1. Connect the Nest Thermostat display via USB to a computer.
  2. Verify that the Nest Thermostat mounts (appears as an attached drive icon).
  • If the Nest drive will not mount: Restart the thermostat and the computer.
  • If the Nest drive still won't mount: Connect another device to the cable to see if it appears as an installed device.
  • If it doesn't appear, use a different cable/port/computer.
If the Nest drive is successfully showing up on your computer, can you see a technicalinfo.PLIST file?
GarrettDS
Just wanted to jump in here to check to make sure that you saw the response from davidking. Shoutout and huge thank you to davidking for the help here. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
