H71 showing- no lights on heat link. willnotnest not working
Matilda2022
H71 showing- no lights on heat link but power going in. not able to connect to thermostat. It seems a very common fault. Solution please
2 REPLIES 2
CristianC
Hello @Matilda2022,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
Cristian
CristianC
Hello again. Just checking in. How's it going with your Heat Link?
