10-22-2025 12:00 PM
I got one of my thermostats up and running. The only issue I have is setting the temps for the heat/cool mode. I set them to what I want and then they will change. There seems to be a standard diff between the heat and cool settings. How can I get it to keep what I put in?
a month ago
Hi @cbsams,
Thank you for posting in the community. I'm sorry to hear that you are having trouble with your Nest Thermostat not holding the temperature you set on it. I'm happy to assist.
To gather the necessary information, please answer the following questions:
Are all your Nest Thermostats the same model?
I'll be waiting for your reply.
Best regards.
Derick.
