Heat link no power
Greg1932
Heat link of my Google Nest is dead. Electrician looked at it and said it has failed. Can I get a replacement?
11 REPLIES 11
nlar
Exact same issue an hour ago. What is the process for getting a replacement unit? There are numerous reports throughout the internet of a specific diode on the circuitry shorting out.
Thanks for reaching out. I'm sorry for the delay. I just want to confirm, in what states are you located? Also, what type of Nest Thermostat do you have? You can visit this link to check what type of thermostat you have.
@Greg1932 and @nlar, checking if you still need help. Please let me know, as I'll be willing to assist you further.
no success in fixing the issue to date
AlexD
Hi @Greg1932 . I would be happy to try and assist. If you haven't already, check the breakers and switches at the location, to make sure nothing has tripped. Also check the boiler as it can sometimes have a separate switch on it. Confirm it has power, it should have a display or LED that turns on.
If it all looks good try and power cycle the Heat Link, if you're comfortable in doing so. Turn the power to the Heat Link off for a few minutes and then turn it back on. See if it has any reaction after, when you press the button on it.
Hi @nlar , you can try these steps as well if you haven't already and let me know how it goes.
Greg1932
Electrician checked it all. Power is being received at the unit but it is dead.
Paul_R
Hello @Greg1932, thanks for confirming. Could I send you an email in order to create a case in our system?
Hi @nlar, I'm glad to hear that the issue has been resolved on one of our support channels. Let me know if I can do anything else to help you.
Paul_R
HI there @Greg1932! Have you seen my previous message?
Paul_R
Hi there. Since you didn't reply in a while, I'll have to close this thread. If anything else comes up, please feel free to reach out again. Have a wonderful day ahead!
UanaC
Hello there @Greg1932 and @nlar! Just checking in with you. Did you see my colleagues previous message?
nlar
Hello. Checked all fuses and circuit breakers. After contacting support via chat a replacement unit will be send to me .
