Heat link not working and no lights
Martin_Ni
3rd Gen The heat link box has failed and had no amber or green led. Tried the 30 sec reset and check fuse board etc.
No heating and need a replacement asap.
Can you help please
Martin_Ni
Hello Google Nest,
I have no heating and I cannot seem to contact you via your online web tool.
All contact boxes are greyed out?
Can you please respond asap?
Thank you
CristianC
Thanks for reaching out. Sorry for the late reply. I'll do my best to get this resolved for you. Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
CristianC
Hello again. Just checking in. How's it going with your Heat Link?
