08-29-2023 12:03 PM
Hi there, my two heat links recently died completely. Neither have a light on them after trying to reset. Completely dead. My electrician took a look but could not understand the issue other than dead heat links. Also I have no led on downstairs thermostat. I’m out of warranty. I feel so disappointed as one heat link was replaced but didn’t work from the get go after installation. Please help.
08-31-2023 07:55 AM
Hi, thanks for reaching out. I'm really sorry to hear about this. Can you please answer the following questions:
1. How long has your thermostat been installed for?
2. What is showing on the Nest thermostat display?
3. Have you had any power cuts recently?
4. Have you had any work done on your electrical or heating systems recently?
5. How many zones are present in the setup?
09-01-2023 01:52 AM
I had a heat link replaced in 2/23 and I was travelling away so my electrician only came to replace it 3 weeks ago and install it. In the meantime my other heat link died ( no lights on either of them). I tried to reset them but nothing . There was no power cuts and my electrician could not solve the issue other than concluding that both heat links were faulty. I have two zones, one upstairs for heating and one downstairs for heat and water. The downstairs heat link has been broken since last winter and more recently my upstairs has stopped working. The upstairs screen says it can’t connect and there is no light on either heat link. The downstairs screen is also dead with a blank screen. I am so frustrated and disappointed with this system. It’s almost winter and I have made no progress in fixing the issue. Can you please advise me how I can replace or fix the issue. My electrician has already spent 3 hours trying to resolve the issues but believes they should be replaced. I have had to pay him for his labor and am at a loss as how to move forward, please help me, Regards
09-03-2023 01:20 AM
Thanks for describing the issue. I'm really sorry and I do understand how frustrating this is. Would you allow me to send you an email on your address that you use here?
09-03-2023 11:27 AM
Yes please, I would appreciate any help. #
09-04-2023 04:10 AM
No worries. I sent an email your way. Just let me know here once you reply to it.
09-07-2023 08:42 AM
Hello there! Just checking in with you. Did you receive my colleagues email?
09-08-2023 09:28 AM
Hey there, I haven't heard from you in a while here, we're in touch over email, I'll be locking this thread. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, AlexD.
