02-24-2022 07:37 AM
I switched from a Honeywell th8320r1003 to a Nest Thermostat for our forced air + heat pump + electric aux system.
The problem I’m seeing after that transition is that often, when the forced air starts, it takes the heat pump something like 5-10 minutes to start spinning. As a result, on cold days we have very cold air blowing around our house until the heat pump turns on.
I did see this on occasion (once or twice a year) with the Honeywell unit, but it’s almost every time with our Nest.
Any ideas? Thanks for the help!
03-02-2022 07:20 PM
Hi Jnieman21,
Sorry to hear about what's going on with your Nest thermostat. I want to dig deeper into this.
A few questions — what specific Nest thermostat do you have? Could you provide a photo of your old Honeywell thermostat's wires as well as your Nest thermostat wires today? Also, if you've already tried some troubleshooting steps, could you provide a brief summary?
Melba
03-09-2022 05:56 PM
Checking back in — still need help with your Nest thermostat?
Melba
03-15-2022 11:10 AM
Hi Melba! Apologies for the delay, and thanks for reaching out.
- I have the "Nest Thermostat" - just the basic, not the Learning: https://store.google.com/us/product/nest_thermostat?pli=1&hl=en-US
- Here's the old:
- Here's the new:
- So far, I've really just played with the settings in the Home app for things like O and B wire for heat pump and Duel fuel breakpoint. Nothing has made much of a difference.
Thank you!
Jacob
07-12-2022 02:57 PM
Hey Jnieman21,
Ryan
10-23-2022 09:10 PM
I had the exact model of Honeywell, and I upgraded to the 3rd gen net learning thermostat. I am currently having the same problem as you, both AC and the emergency/aux heat work find. But when I turn it to regular heat it just blows cold air.
10-23-2022 10:40 PM
Still happening to me, but it hasn't in quite some time due to season. I guess we'll find out in a week or two here 😬
10-26-2022 05:20 PM
@Jnieman21, I'm sorry to hear that you're still experiencing this issue. Please observe it and let us know if it's still happening once you need to turn the heat on.
@Cmoody53, Thanks for reaching out. Could you share how your Nest Thermostat is wired and its power readings? You could find this info by going to Settings > Technical Info > Power.
Edward
10-31-2022 11:59 AM
I wanted to check in and see if you managed to see Edward's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
11-01-2022 09:53 AM
