Heat pump won't stop heating
rocksf
My heat pump won't stop heating after it has reached the set point.
e.g. if I set it to 70 degrees, it will keep running. I can wake up to a 90-degree home.
Cooling works fine.
When the heat pump keeps going, I can change to cool and then immediately turn it off.
e.g. Heat set point 70, reaches 90
turn on cool
turn off cool
Houptee
Did this happen after a new installation of a nest or was nest working properly then this problem started?
rocksf
New nest.
It *feels* like the heat wants to turn off, but it doesn't.
Jeff
In an effort to keep content fresh on the forums here and prioritize current issues, I'm going to go ahead and close up this thread. If you have any outstanding issues from this post or any other problems, please feel free to open up a new discussion.
Jeff
