10-11-2021 05:14 AM
I installed my Nest thermostats last February (not sure the model -- basic model with no color screen). They worked flawlessly all winter, even with no c-wire for power. When the furnace was not being used as much, I was getting the low power issue. I installed c-wire to the NEST and that solved the issue. Now, months later, I turned the heat on and I'm not getting anything (I have a hot water radiator system). I have one old thermostat in the house in a zone that still works fine to engage heat (so it tells me the system is working fine to produce heat). In my case, the Nest engages heat control valves to kick on furnace -- that isn't happening. The Nest says heating and gives a 1hr30min estimate, but nothing kicks on like it used to. I tried factory reset, nothing. I changed out a motor on the flow control valve -- still nothing, so it tells me it wasn't a burned out valve motor (as is common). Any suggestions?
11-09-2021 02:30 PM
Hey laserkalin,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
11-09-2021 07:04 PM
I fixed the utility part; now I'm getting a low battery, however, I have an external power supply hooked up. Not sure I'm doing that correctly? I have two wires going through a single terminal.
11-23-2021 11:25 AM
Hey laserkalin,
There is a chance something may not be hooked up correctly. Do you mind me asking if you could send in a picture of your current wire setup for me to review? I also did find an article that provides some troubleshooting steps for strange cooling/heating behavior. Let me know if that helps out, and once the picture has been sent.
11-29-2021 12:49 PM
Hey laserkalin,
I wanted to follow up and see if you were still in need of any help? I would be happy to review the wire setup, and ensure you are good to go. Please let me know once that has been sent so I can review.
12-02-2021 10:54 AM
Hey laserkalin,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
12-06-2021 03:01 PM
Hey laserkalin,
It has been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions, please feel free to create a new post.
