05-30-2023 08:33 AM
Hi, I have a nest learning thermostat which was installed May 2019. Just recently I got a H72 error on the thermostat. I checked the heat link and see it is totally dead, no lights. Tried to reset but no joy. Can I order a new one? Thank you
05-31-2023 04:17 AM
Hi there! Thanks for posting. I'm sorry to hear that you've encountered issues with your Heat Link, but I'll do my best to help out. Can you please answer to these questions:
1. Have you had any power cuts recently?
2. Have you had any work done on your electrical or heating systems recently?
3. How many zones are present in the setup?
05-31-2023 08:10 AM
Hi thanks for the follow up response. I have had no power cut or any works done, we have one zone. Thank
05-31-2023 10:13 AM
Thanks for letting me know! Can you please try or confirm the following troubleshooting steps:
1. Check if all the breaker switches are turned on.
2. Turned the breaker switches off and back on.
3. Try to turn on manual mode.
05-31-2023 10:17 AM
Tried all of these and confirmed it has power but still no light showing on the heatlink. Thanks
06-01-2023 12:59 AM
Hi there @Lconnolly17! Thanks for confirming the steps as well. Can I send you an email with a form, in order to be able to create a case in our system?
06-02-2023 12:39 AM
Hi yes please attach form, thanks or email
06-02-2023 02:50 AM
I sent the email your way. Go through it and let me know here once you have.
06-04-2023 03:08 AM
Hello there! Just checking in with you. Did you see my colleague's previous message?
06-06-2023 03:11 AM
Hi there! Since you haven't replied in a while, I'll need to close this thread. If anything else comes up, please feel free to reach out again. Have a wonderful day ahead!
