Help please nest e thermostat
ntj1971
I am thinking of buying the thermostat e.Currently my thermostat is located in the hallway which is a lot cooler than our living room.If we want it to be 18 degrees in our living room we change the stat to 18.The living room can be 18 degrees (we have an electronic thermometer) but the thermostat will be showing  at 15 degrees and the boiler is still running.My question is does the thermostat e use the replacement heatlink e(replaces hallway stat) as the thermostat or use the actual nest e thermostat which would be located in our living room as the thermostat?Hope this makes sense!!
0 REPLIES 0
