Help with Nest thermostat
Jcarr
Help our Nest thermostat will not work. After getting our vents cleaned the nest thermostat power died. Recharged and put it on the wall and gave us code no wire Rh. Rebooted the nest and it died turned off saying low battery. Help we need heat
Perhaps when they were cleaning the duct, they damaged the cable and cut a conductor.
To test for this you’re going to have to get a volt ohm meter and run a continuity test of your cables from end to end. If you want to test this, let me know and can describe how to test and find a broken wire.
Ken, The AC Cooling Wizard
aatienza
Hey Jcarr,
I'd like to jump in here and check if you've seen CoolingWizard's response. Let us know if you need more help by replying to this thread.
I appreciate the help, CoolingWizard.
Archie
EmersonB
Hello everyone,
@Jcarr, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, CoolingWizard and Archie.
EmersonB
Hello Jcarr,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
