10-01-2022 09:16 AM
Hiya.
I installed 3 Nest thermostats and need to install the power connector. I’m a decent DIYer but this stuff is new to me as I’ve only ever had pellet stoves. 🙂
Does this look like the panel I can install the power connector on? It’s an oil furnace with hot water baseboards.
Thanks!
10-06-2022 11:56 AM
I wanted to follow up and see I could be of any help. I found an article with more details on the Nest Power Connector. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
10-10-2022 10:43 AM
I wanted to check in and see if you are still in need of any help with your device. Please let me know, as I would be happy to assist, and answer any questions you may have.
10-11-2022 10:12 AM
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
10-11-2022 11:13 AM
Thanks Jake. I still can’t seem to figure out where to start. I read all the help docs and info and still can’t seem to find straightforward directions for my particular setup.
I might have to make an appointment with a professional 😞
10-13-2022 09:30 AM
Hey StormShaman,
I am sorry to hear you are having issues setting up the device still. I would recommend having a pro come out, and set that up for you if you are having trouble. That will ensure everything is set up correctly, and no issues will arise. Please let me know if you have any questions from here, as I would be happy to take a closer look.
10-19-2022 11:21 AM
Hey StormShaman,
I wanted to check in with you, and see if you were able to get a HVAC pro to come out, and take a closer look. Were they able to get the issue resolved? Please let me know, as I want to ensure you are good to go.
10-20-2022 11:08 AM
Hey StormShaman,
