01-25-2022 03:57 PM
I currently have a lux product thermostat , is this system compatible with a google nest ?
01-25-2022 04:55 PM
Yes, it's possible. Try the Nest App. It comes with step-by-step guide instructions that make it very easy to install.
01-26-2022 02:04 PM
You can check your compatibility here:
