High power readings
Katm995
my power readings for my nest thermostat seem very high. I do not have a c wire installed. I have Y-G-R-W. The picture is when the unit is on. Similar readings when it is off. I also hear a clicking noise when I am close to the thermostat and it’s running. Is this normal or should I be concerned?
7 REPLIES 7
listairee
Hello @Katm995,
Thanks for reaching out. Here are the ideal power range if there isn't a C wire in your thermostat, according to Google:-
  • Voc: 29 to 42V
  • Vin: 29 to 42V when your system is not running (6 to 7V when your system is running)
  • Iin: 20 to 40 mA
It looks normal for the voltage readings.
Hope that helps! 🙂
Mine is over 30 V when it is running. Doesn’t seem like the normal range you listed
Hello @Katm995,
Is it possible for you to provide an image on your wiring to further help you diagnose?
Thank you.
I added the pics to the original post
zoeuvre
Hi @Katm995
Thank you for taking the time to contact us. It appears that you're experiencing power-related issues. To better check this, can you please help me with the make and model of your HVAC system?
I appreciate the help, @listairee
Chiming in — I just wanted to know if you still need help. Please let us know, as I'll be willing to assist you further.
I appreciate your help, @listairee and Zoe.
Hello there,
