Home/Away Assist Problems
junalmeida
The home/away assist is not working as expected. It often thinks I'm away when I am home, and turns it to Eco mode. Today I am not home, and it thinks it is, heating the house for no one.
Everything seems to be set correctly, and yet the support team suggestion is to "buy another phone".
JohnV
I am having the same issue. It is a pretty crappy app that only works some of the time. This is absolutely the worst performing application I have ever used. I have also double checked all settings, reinstalled app, logged out / logged in and no change in behavior. I leave the house and get far enough away that it should go into away mode. Sometimes when I look at the app, it is fine and in away mode, other times when I open the app, THEN it decides to go into away mode. I have location settings set to always on my iPhone. Yesterday, I left and went for a walk at least 1/2 mile away from home and it never went into away mode.
This is really frustrating as I have to remember to check the app when I am gone to make sure it actually went into away mode. What good is having a "location aware" app if it only works 'some of the time"???
And no, I do not need another phone, I have other "location aware" apps that are working just fine and very reliably.
junalmeida
It is interesting to see that you use an iPhone, and I use an Android, so it could really be a widespread issue. Unfortunately support guys refuse to see they have a problem, and leave their customers frustrated. If only I could do the same for my customers, I would earn money easy, right?
JohnV
Totally agree. I develop software to do systems integration for a number of clients - not that hard to monitor to see what is going on and provide a fix... 🙂
LifeonMars
Having a similar problem recently in the UK. iPhone Home/away not always switching when away. I have reset everything and some days when i am out, I check the settings and find that no events are shown and the Thermostat has not switched to away., even though I have been a long way a way from home.  This is only happening recently, prior I had no problems with the same phone.
