Hook gas furance to heat pump
Cw101
I have a wetherking furance with y,w,g,r,
and a heat pump with red , yellow, white, blue, orange
I know orange goes to thermostat wire orange
but can someone tell me how to wire this up correctly
thanks
MelbaDT
Hey Cw101,
Thanks for reaching out.
Could you share a clear photo of your current thermostat wires showing the terminal labels where the wires are connected to so I can have a closer look? Also, what Nest thermostat are you trying to install?
Melba
MelbaDT
How's it going? Still need our help?
Melba
MelbaDT
Melba
