Hot water always on
Robtla
Bacteria prevention is turned off and hot water turned off but still 240v on number 6 terminal calling for hot water?
9 REPLIES 9
AlexD
Thanks for reaching out here @Robtla . I would be happy to try and assist.
Just to check, is this a new installation?
How many LED lights do you see on the Heat Link?
Do you see any kind of water drop icon on the thermostat display under the set temperature?
Does it state that the hot water schedule is inactive in the Nest app?
Johnmuk76
Same issue
one led orange water drop on thermostat
hw schedule active
UanaC
Hi @Johnmuk76, thanks for bringing this to our attention. I'm really sorry about any inconvenience created. Can you please go into your thermostat Settings -> Equipment -> Bacteria Prevention and disable this feature? Please let me know if this solves your problem or not.
Thanks in advance, Uana.
UanaC
Hello all! Just checking in, did you see my previous messages?
UanaC
Hello there @Robtla! Just checking in with you. Does your issue still persists?
DonalF
Did you get to the bottom of this issue? Having the same/a similar issue with mine, so keen to know of any progress. Cheers!
LarisaL
Hi there! Can you tell me what color the LEDs from the Heat Link are? Also do you see any icons on the thermostat display?
DonalF
The LED light is green on the heat link (single green). The thermostat display appears with al the usual icons, with the hot water setting OFF. The hot water schedule is off, but the booster heater seems to be hot/permanently on at the water tank.
Paul_R
Thanks for the details @DonalF. Could you please go to Settings > Equipment > Pro Setup and send us a photo of how your thermostat is set?
