How do you know if the power is off when Nest has a battery?
Bewma
How do you know if the power is off when Nest has a battery?  I am taking my nest E off the wall to paint and I can't find which breaker it right because the internal battery keep the Nest on.  Is there a way to disconnect the battery so I can see when it goes off?
@Bewma ,
Your power panel should have have the circuit breaker labeled.  Alternatively, if you know where your indoor air handler is, national electrical code requires there to be a power disconnect located near the air handler. Find it, turn it off and the power to your thermostat will be off as well..
AC Cooling Wizard
