01-11-2024 01:50 PM
hello,
i recently purchased a Nest Thermostat + Nest connector to replace my thermostat. I have a Hybrid dual fuel (Gas + Heat Pump) heating + cooling hvac. Using the app I was able to connect the equipment and got the heating system to work. However Nest does not recognize the cooling capability of my hvac.
Available wires are R, W, Y and G at the board and connected to RC (+ jumper to RH), W/B, Y/0 and G respectively.
New installation with Nest;
Nest thermostat W wire directly to W, G direct to G
Nest connector Y to Y and R to R. Output C, R, Y to the thermostat.
thanks to let me know how I can get Nest Thermostat to recognize the cooling function
02-03-2024 02:08 PM
Hello MuNster,
It sounds like you've made some progress in getting your Nest Thermostat set up with the heating function but are encountering issues with the cooling capability. Here are a few steps you can try to help Nest recognize the cooling function:
Let us know how it goes.
