11-29-2021 01:50 AM
I have red blue green wire in my cooling system. I forgot to click the pic of existing setup. Where will goes the wiring ?
11-29-2021 09:25 AM
It is very hard to give you an accurate answer without a picture of the old thermostat wiring, but try the following it should work:
- Red to Rc or R.
- Blue to Y1 or Y
- Green to G
11-29-2021 09:25 AM
- Red to Rc or R.
- Blue to Y1 or Y
- Green to G
11-30-2021 03:00 AM
Thanks, which Nest thermostat I should buy
11-30-2021 04:19 AM
The Nest thermostat 2020 (the one with the mirrored faceplate) is usually cheaper and should work fine for your use case.
