08-10-2025 05:35 AM - edited 08-10-2025 05:36 AM
I wanted to confirm if my current wiring for my current HVAC system (4-pipe, vertical fan coil
unit) is compatible for Google Nest thermostat? The wires as shown below are: W, F, T, G, R, Y, 1, 2, 3
08-10-2025 08:44 PM
Based on the labels on your current thermostat, I would say no.
08-10-2025 08:44 PM
08-10-2025 10:24 PM
Based on the wiring you’ve listed (W, F, T, G, R, Y, 1, 2, 3), it appears your system uses a control configuration that may not be directly compatible with the Google Nest thermostat, as Nest is designed primarily for conventional or heat pump systems with standard HVAC terminal designations
