09-10-2023 07:44 PM
Ok, I'm a bit confused. I understand the security software is being replaced, but I am trying to find out if the Nest Sense for my thermostat is being replaced, I saw the message "Starting September 29, 2023, all Works with Nest connections will stop working. ".
Is sense part of Works?
09-13-2023 01:50 PM
Hello mbrouill,
Thanks for posting here in the Community. Nest sense is an added feature on a Nest device that makes it more thoughtful. For example, the Nest thermostat uses multiple sensors and algorithms to help keep your house more comfortable and save energy. While Works with Nest is a feature added to a Nest device to help integrate with a third-party device on the Nest App. Nest sense will not be affected even after the support for works with Nest ends on September 29, 2023. Here is a link to learn about Nest sense.
Let me know if you have additional questions.
Edmond
