Is my power compatible with Nest Learning Thermostat?
jmcg
I am not sure my old wiring is compatible. Based on the photo of my existing thermostat, is this wiring compatible with the new Nest Learning Thermostat? Wires are G W and RH
Thanks in advance,
JMcG
My old thermostatMy old thermostat
Your current thermostat only controls a heating system and the air handler blower fan. This system appears compatible with a nest thermostat.
Ken, AC Cooling Wizard
Thank you Mr. Wizard!
Jhonleanmel
We appreciate your help here, @CoolingWizard.
@jmcg, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
EdwardT
Edward
Jhonleanmel
Mel
