Is my system compatible with Nest?
Shell802
6 REPLIES 6
@Shell802
Yes, your system is compatible with any Nest thermostat.
Try this wiring
White - W to W1 or W
Yellow - Y to Y1 or Y
Green - G to G
Red - R to Rc or R
Blue - If the blue wire is not connected, then I strongly suggest that you use it to create a C wire by connecting it to the C terminal on both ends
The "or" is for the Google Nest Thermostat wiring
@Patrick_Caezza  Thank you very much! I just ordered one
zoeuvre
Hi Shell802,
I'm glad to hear that everything has been sorted out. On the other hand, here are some helpful articles that will help you install and set up your Nest Thermostat for your reference:
In the meantime, I'll go ahead and lock this thread within 24 hours. If you run into any more questions in the future, please feel free to create a new thread.
Thanks for all your help here, @Patrick_Caezza and Jake.
Hey Shell802,
Thanks for the helpful reply Patrick_Caezza.
I wanted to check in and see if you managed to see Patrick_Caezza post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
Shell802
I am good. I just ordered a nest. Hopefully installation will go smoothly. Thanks!
Hi Shell802,
