12-27-2023 02:01 PM
There are 6 pins for 6 wires labeled N, L, V1, LOW, MED, HI. Can anyone tell me if I can install the nest thermostat with these wires
01-04-2024 07:30 AM
Hello OAA,
Thanks for reaching out here in the Google Nest Community. I'd be happy to take a look into this for you.
Typically, Nest Thermostats are compatible with a variety of HVAC systems. Before proceeding with the installation, here's a general guide to help you:
Accurate wiring is crucial for the proper functioning of your Nest Thermostat and HVAC system. I'd suggest contacting a local HVAC technician for the configuration.
Let us know if you have more questions.
