03-07-2022 10:28 AM
I am wondering if my old thermostat/system is compatible to be replaced by a Google Nest. Low voltage White-rodgers thermostat. It has W, RH, B, RC, G, O, Y connections. A jump wire from RH to RC was connected. B and I are not connected to anything. Thank you
03-07-2022 05:01 PM
It should be compatible depending on model. However you do not have a C (common) wire currently in use. In some cases it is required for a Nest Thermostat. You may need to use one of the spare wires (typically blue) to connect C at both the HVAC unit and thermostat.
You can also use the Compatibility Checker to verify if your system will work with a Nest Thermostat and to get more information.
03-07-2022 05:57 PM
Do you know if the Blue wire is connected to anything at the hvac system? You will need a Common (C) wire from the hvac system and that is usually the Blue wire. Other than that wiring issue, yes, that would be compatible with a Nest.
03-07-2022 06:43 PM
From what I can tell in the picture you must have a straight cool system with electric heating. Nest should work with no issues. hard to tell from the picture but is the blue wire terminated on the C post of the thermostat? When you wire the Nest you do not need a jumper between the RC & RH post. That's automatically connected internally with the Nest. Just FYI, G(green) is your blower, Y(yellow) is your cooling, W(white is your heating, and R(red) is your power from transformer If Blue is on the C post, that is your common to the transformer.
03-07-2022 07:42 PM
Your current thermostat is compatible with any of the Nest thermostats.
Try this wiring,
White - W to W1 or W
Red - RC to Rc or R (jumper to RH not needed)
Green - G to G
Yellow - Y to Y1 or Y
As others have said, I would suggest using the blue wire as a C wire. Look on the control board in the furnace and see if there is a C terminal. It will probably have one wire on it, just add the Blue wire to the terminal and then connect it to the C terminal at the thermostat,
03-10-2022 10:49 PM
Thanks again for responding here, Patrick_Caezza, RomanandsonAC, dhx227, and sporfrog.
BevanFN, I'm chiming in to check if everything is covered here. Feel free to reply back if you have more questions.
Melba
03-15-2022 04:54 PM
Hey BevanFN,
Checking back in ― still have some questions about our Nest thermostats?
Melba
03-16-2022 06:39 PM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. Should you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
