Lock max temperature on Nest thermostat
Foremarke
Hi
how can I stop my family from constantly turning up the temperature on our Nest thermostat.
I keep reading that it can be done, but I can't work it out
2 REPLIES 2
Frustratedddd
I used a search engine, one called Google, and typed in this.... google nest thermostat lock code
I then found this, might help you
https://www.google.com/search?client=firefox-b-d&q=google+nest+thermostat+lock+code
Hello everyone,
I'm chiming in to make sure everything is covered here.
Thanks for the input, @Frustratedddd.
@Foremarke, dealing with temperature adjustments in a shared living space can be challenging, but there are a few strategies you can try to maintain a comfortable environment for everyone. The Lock and unlock your Nest Thermostat feature can be helpful so you can set a temperature range for them to adjust by not being able to navigate and going to its settings.
Let us know if that helps.
