12-12-2023 04:06 PM
I use a temperature sensor to manage heat in a room adjacent to the actual thermostat. Not able to set the temperature in the Home app, just the Nest app. Is it possible to actually set the temperature in the Home app?
The Home app gives me a reading, but does not let me set the temp.
12-17-2023 09:07 AM
Hi Cnfzd-2,
Thanks for posting. Currently, Nest Temperature Sensors can only be controlled via Nest app. Nest Temperature Sensors are used to provide temperature readings and assist the Nest Thermostat in making informed adjustments. However, the Home app's ability to set the temperature directly within the app may depend on the integration and compatibility between the Nest Thermostat and the Home app. To have full control over temperature adjustments, the dedicated Nest app is recommended, designed by Nest/Google to provide comprehensive control and customization options for their thermostat products. Learn about the Nest Temperature Sensor here in this link.
Let us know if that helps.
