a week ago
Just moved into a new home. We don't have the pin for the existing Nest Thermostat. I'm unable to add the app or gain access to the device. Is there a way to do a factory reset? Please help!
a week ago
In your situation I suggest you fill out the entire following form to connect directly with Google Nest Support:
Monday
jHal, checking in — were you able to reach out to our support team for assistance?
I appreciate the help, MsDrasby.
Archie
