10-31-2021 10:10 PM
I can start both the heater and the air conditioner manually with my nest thermostat, but it is not starting them based on temperature. For example, if I set the heat to turn on at 68 degrees, even when the house temperature goes below 68 it won't start the heater. The same with the air conditioning. However, when I run the heating or AC unit manually from the thermostat, they will turn on.
11-08-2021 02:54 PM
So, I finally got some help from Google. The fix seems to be to do a full factory reset of the thermostat. Obviously you’ll lose your programmed temperatures.
11-03-2021 01:08 PM
No answer, but I’m having the same issue this week. Nest set to 68, but it’s 65 in the house and not turning on the furnace.
11-04-2021 09:28 PM
Yep..same issue here
11-20-2021 05:17 AM
I'm having the same issue. I reset mine to factory settings and it worked fine for two days and now I'm experiencing the issue again.
12-19-2021 08:53 AM
Same problem here, and it's been very frustrating. Also, both myself and my cats are developing upper respiratory colds from the cold & dampness now in my home
01-08-2022 08:22 AM
If I understood right - resetting the thermostat didn’t work for you. Do you have another Fix?
11-04-2021 09:27 PM
I started experiencing the same issue on Nov 2nd after an automatic update was done. I have several nest thermostats in my house and when I swapped them the issue followed the controller so I know it's not the compressor or hvac. Has to be the controller and from the looks of this thread it's a bug from the update. Other 2 nest thermostats didn't update on Nov 2nd. Google please help!!
11-08-2021 01:30 PM
Having the same issue - any fixes reported by @User123456 ?
12-09-2021 04:45 AM
Issues continue. I've noticed my system will run for exactly five mins. then turns off. 6-2.22 is the issue and I'm ticked off.
We had some warm days for the past week, so I didn't have to run it. Cold weather is back...getting off nest this week unless they push an update.
11-08-2021 02:54 PM
12-18-2021 08:45 AM
Same issue, why doesn’t Google respond?
12-18-2021 02:46 PM
I did speak with them on the phone when this happened. They were very helpful. The issue is I can't remember how they helped me fix it. I would try calling them. Sorry I'm not more help.
12-18-2021 02:47 PM
Reply above was how they helped. I also did a full factory reset on the thermostat.
02-14-2022 12:41 PM
I had the same problem - Nest (Model: Snow GA01334-US ) says HEATING, but it is not starting the fan. My solution :
- Go Thermostat -> Settings -> Thermostat -> Equipment ( Heat configuration ) -> Fan activation
- Set "Activate" (because default is "don't activate" that prevent turning a fan on automatically)
P.S. This option was available in the initial set up but switches to default for some reason.
02-27-2022 06:37 AM
How do I call them? I don't have a number?
12-19-2022 11:39 AM
Good question. I have searched for a Google technical support or customer support number but without success.
12-23-2022 09:57 AM
Can someone please provide the phone number, thank you
